Config LED OP17
I never worked with OP17 and i do not have the software installed anymore so in Protool this should be something like this:
system->Areapointer
add-> Led assignment (e.g. MW10)
then:
System->Screen/keys
Goto the K-key (General) and choose what bits you will use to control the led on the key.
bit n+1 bit n led
0 0 off
0 1 2 Hz
1 0 0,5 Hz
1 1 on
Hello, I recently made changes to a preexisting HMI. I was able to create the runtime file but when I try and run the program on my desktop it...
8,636
Hey guys, I made some changes to an rslogix 5000 program to incorporate HMI and field I/O. I compiled a new runtime file for the new HMI program...
3,401
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
92
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
222
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
89
