Config OPC UA with two plc
huynhtrong
Aug 2017
ho chi minh
Hi all,
i'm researching about OPC UA.I used simulation plc sim advanced in plc s7 1500 is OPC UA server and test in app client.It's work.
Now I want to read and write data between two plc.server and client.
How to config to get data in server and client?
S7 1500 can only be an OPC UA Server right now. I'm assuming client functionality will come with the next version, whenever that comes out.
If you need to talk PLC to PLC, then I'd recommend I-Device, an S7 connection, or TCP.
Hello Guys, I need your support for OPC configuration of Packdrive C600 controller. My PLC is connected to a network vlan and I installed OPC...
1,677
hi, Can you guys help me out in understanding the function of DDE/OPC , topic config in RSlinx software.
2,855
I have a SCADA system setup on network in my plant. I have (2) PLC systems that are Allen Bradley that I can not talk to? I have tried to set up...
18
11,880
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
80
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
210
