Configuration of Siemens FM351
snraops
Feb 2007
Bangalore
Hi All,
I am using positioning module FM351 first time. I want to connect an absolute linear encoder (MTS, German)in channel 1 and an incremental encoder in channel 2. Can anybody help. The procedure given in example is complecated. I am not using any drives. I want to use this to just take feed back of moving object.
Thanks & Regards
Fm354
Hi Snraops,
Where you successfull in writing the code? Me too in need of the Programme code for using Absolute encoder with SSI output. I am using a Positioning module FM354 to process the data from encoder and use the PLC to display in HMI. I have worked out with the background and technical details but struggling with the coding . If you have do let me know.
Regards,
Vijay
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
477
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
105
General Question: The PLC and HMI that I've been working on (a laser measurement system) is soon to be transported to the site where it will be...
706
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,208
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,720
