Yoki Member Y Join Date Jan 2007 Location Jakarta Posts 5 Jan 7, 2008 #1 Dear All; Somebody help, how and what do I need if want configure RSview32 with IO server redundant? Do RSlink gateway enough as IO server for this application? Thanks, Yoki
Ken Roach Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Seattle, WA Posts 17,490 Jan 7, 2008 #2 "IO Server" is a Wonderware term. RSView32 uses "OPC Data Servers". RSLinx OEM is a sufficient data server for RSView32 on a single computer. To use RSLinx data servers on multiple computers as a "redundant data server" mechanism, you need the Remote OPC Server capability of RSLinx Gateway. The RSView32 application can switch between OPC Data Servers using VBA code. There is a good example of this on the RA Knowledgebase as Document ID # 20755.
