Configuring a 1746sc-INI4vi module
cirtcele
Apr 2007
Illinois
64
Do you enable this module by opening the output data file for this modules address and changing the bits as described in the manual. I just want to be sure that i'm understanding this correctly. :oops::oops::oops:
Your understanding is correct. Words 0 through 3 of the output image table for the module set the configuration of the input channels. Words 4 through 7 are used to set the limits of the two user defined scales.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
787
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
595
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
665
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,171
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,278
