Configuring a 1783-NATR device trouble
Automatedsoup
Sep 2020
Boston
Hello all,
First post so here goes.
Trying to initially configure a AB 1783-NATR device. First time I've tried this. Using the 1783-NATR user manual and following it step by step. I get to point where it tells me to reset the device. When I do, a message appears saying "Rebooting, please be patient". After about 4 hours of being patient I factory reset the device and tried again. Same thing. I tried another NAT and same thing. Does anybody have any experience with doing this?
I had a similar issue with a NAT device.
In the end, I saved the profile from a good device to an SD card.
Put the SD card into the one I was trying to set up and uploaded the profile.
After it rebooted I set the 1 to 1 translations and rebooted it again.
The rest of the process that we use is standardized so all I had to do was set the public and private IP address for translation as well as the device IP.
Once everything was set up I connected it to the plant network and everything worked out.
don't hit the reset module. The warning says this "Resetting the module causes all connections to or through the module to be closed, and this may result in loss of control?
Instead the better alternative is unplug the power and power it back and that will keep all your changes and you don't need to wait for 4 hours.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
779
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
593
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
661
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,156
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,271
