Configuring a 5069-IB8S field input
Gi1gamesh1
Apr 2021
Beloit, WI
Edit 1: The mystery deepens. I fixed the below issue when I use an external power source for my field device but I want to configure the test output points on the IB8S as 24vdc power supplies. When I do this I get 0 volts out. Thoughts?
I have a Compact GuardLogix 5380 with the following cards:
Slot 1) IB8S
Slot 2) IB8S
Slot 3) OB8S
Slot 4) IF8
I've connected my field device (STBVP6) to inputs 0/1 of Slot 2.
The field device has power and shows an output light when I activate it but the actual input on slot 2 has a red icon.
In my Logix Designer I configured slot 2 Input points 0 and 1 as Safety each.
Does anyone know what I am doing wrong? In the program I can read there is a fault on those points but not data.
Thanks for any assistance.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
782
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
595
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
663
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,167
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,274
