Configuring and controlling a PowerFlex 70.
pranesh3994
Mar 2010
College Station, TX
Processor = Control Logix 5000
Drive= AB PowerFlex 70
Communication = DeviceNet
Hello,
I am trying to actually run the Motor with the VFD using RSlogix 5000 and i do not have a proper idea as to how to go about it. All i need is, I Have all the Rockwell Software, and the above mentioned hardware. Can you please guide me as how to go about configuring and finally programming.
You will need RSNetworx for DeviceNet as well to set up the DeviceNet Network. Do you have that?
Stu.....
the other option would be to use an analog output card and send a frequency reference rather than through the devicenet.
Yes, I have RSNetworx for device net. The setup is already done. the Powerflex is connected through the devicenet and I have all the required software. I am looking for instructions on how to start off.
Okaayyy. If all the setup is done, I am not sure what you are asking. I assume from that statement, you have the Powerflex (Which Powerflex?) Comm Card addressed, and in the Scanners Scan List. The Powerflex DeviceNet Card Manual will have the Command and Status Words. For example, it is in Appendix D for the 20-COMM-D Manual. This will tell you which Command Word Bits to turn on for Run, Stop, and Jog etc. You can also monitor the Status Word Bits for Run, Alarm, and Fault Status etc. Perhaps if you asked specific questions, we might better be able to help you.
Stu....
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
124
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
815
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
607
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
677
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,206
