Confirming Analog output
sparks636
Nov 2005
newmarket
Hey me again. I have tried to make a simple analog program, where I make an input activate a "mov" function. I move (source:32767,dest:N7:whatever), and then do another "mov" (source:N7:whatever, dest:O:1.0). What I am trying to do is get some sort of analog output out of my card. Am I doing this right, and if I have my settings as 4-20, if I put in 32767 should I not get 20ma out? Any help will do, thanks!
I think you're on the right track, however you may want to check your output/input card configuration and scaling.
In "most" cases you'll be using 3277-16384 equals 4-20ma. Somewhere in the input/output card documentation you will find what numbers you can expect to see.
I hope this helps you a little.
This is pretty cool.....it's about time I can offer some assistance to someone else :)
I have a machine that requires different sized change parts to run different products and having the wrong change part will cause a pretty serious...
3,502
Does anyone know how to test Siemens PC/PPI cable(6ES7 901-3BF00-0XA0) to make sure it is working? Also can we connect to a Siemens PLC S7-200 CPU...
3,502
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
42
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
130
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
143
