Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario:
My outputs are both on (120v coming out of both outputs).
Im getting 120 volts through my fusible terminalblocks
and im also getting 120v at my light.
The lights will NOT turn on although all this is true, however when i pull the fuses for either output and put it back in the light will turn on. and begin to flash automatically.
I think the light may have also turned on and began to flash when i measured from my hot to ground at my light?
its a red beacon light that flashes automatically (without any programming)
