connect s7 to wincc with pc adaptor?
mansoreh
Apr 2004
17
hi folks
I want to connect s7-300 siemens to wincc v6(sp2) with pc adaptor
is it possible?(for learning and teaching)
Yes it is possible, I used to use a PC Adaptor on my test rig testing bits & pieces with WinCC V6.0.
Regards
Steve
hi stevo
it is intersting.please explain it(
esp about its configuration in wincc) becouse I am novice in wincc
in general is it necessary to configure sth in plc to connect to wincc?
Hi Guys,
To setup an MPI connection between WinCC & S7300, You need to set PG/PC Interface to MPI [Wincc] -->PC Adaptor[MPI]
via either Simatic manager or Control Panel
As for creating your first project download "Getting started with Wincc" PDF from the link below, This is what i used to experiment!
http://www4.ad.siemens.de/-snm-0135...ib.csFetch&nodeid=17413658&forcedownload=true
This covers Tag & Screen creation and Comm's setup.
Hopefully this helps!
regards Steve ;)
I think that WinCC need only for information canal.And it does not matter what devece does this canal. I use PLCsimulator S7 3XX/4XX for this task. And all was OK. I use this chain on my home computer.
I become confused,you mean we don,t need cp card in our pc and we can
connect pc to plc directly if so please explain more about its
Maybe my english is very hazy. I mean that there is PLCsim. It is program than can simulate CP card and PLC. It is like-> you run PLCsim, it is launched and represents you window where you can set MPI address, stop, run, reset memeory and etc for virtual PLC, and you can get many small window that has checkboxies. These windows represent you memory, datablok byte, word, etc, address, DB registers, ACCU1 and ACCU2 or ACCU1-ACCU4 in case if you have S7-4XX in your project. You must download your project to virtual PLC bevore you can monitor and etc. I hope that anybody PLCs men heard about program like this one.
The only difference i can see from the setup you want and what i used to use, Is that on my Laptop i have Wincc & Step7 softare, As regards just running Wincc without Step 7 i can honestly say i havent tried or needed to.
Do you already possess the equipment required for setup? if so hook it up and have a play. Otherwise play it safe and order a PCI type CP & simatic net package.
alternatively contact your local siemens rep and ask advice on what you are about to undertake
good luck
Steve
Hello everyone is it possible to connect the studio logix5000 emulate to a siemens wincc 7.5 running on another pc? if so, what do i have to do...
500
Hi everybody. Please help me. i want to know is it poosible to write SCADA program for a CJ2M-CPU31 OMRON PLC in WINCC program? Programming of...
1,419
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,246
Hello all, The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC...
3,011
Hello, I'm working on set up connection between OPC Kepware V5 (running on PC A) and WinCC V7.0 (running on PC B). Basically OPC (as server) to...
4,255
