Connect Schneider Premium to Siemens S7
aikona
Oct 2003
B2220 plaas dorpie
182
I want (need) to connect a schneider premium PLC with a Siemens S7-400 PLC using TCPIP but if I read this correctly schneider uses modbus tcp against 'normal'tcp on Siemens PLC's . Some info on 'HowTo' . My knowledge of Schneider is zero ( yet)
Eric
Premium has both Modbus TCP and Open TCP
With Premium, you can use two protocols on TCP/IP. The first is the most used protocol for automation over Ethernet ... Modbus. There is plenty of gateways to connect third party, even a Siemens :)
Otherwise,, you can also run the Profinet routines inside a Ethernet module of a Premium using a totally open format called Open TCP. Here you directly address the Ethernet socket. It's quite complicated so I came to know that Schneider has developped a ready-to-use library package for that. I've seen a demo once and that's great. You should try to contact Schneider teams in US who developped that.
Gizmir
We bought a package from Siemens ( TCP_Modbus) and will install one of these days ... I may call on you again soon , si ca vous derange pas .
Eric
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
147
I am currently trying to back up our factory's PLC programs. I have successfully backed up our M340s and am now on to the M258's. I have two...
2,096
Is there a trick to connecting a PC to the Schneider Electric HMIGTO4310? I have tried a straight USB mini connector, the XBT ZG935 cable thru the...
2,884
Hi, This is the current situation: Machine with Schneider PLC. TSX573623A to be exact. Slot 2 of rakc contains ETY PORT. Ethernet card is...
6,044
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
51
