connect to panlview plus 700
artur
Apr 2007
kakanda
18
i have problem to connect me to the panelview plus 700.
I have connect via ethernet with rslinx classic to my plc ( logix 5561 ) but i dont see the panelview.
I dont know the ip adress from the panelview, if i try the ip adress that i think its for the panel view , then i see in rswho only a yellow question mark with a red cross.
the next question is,,,,, can i upload the application from the panelview to my rsview programm, because i dont have the project on my laptop.
thx for help a beginner in allan bradley
my problem was, that i dont use rslinks enterprise,,,, but now i have connect to my panelview plus 700.
i downloadet now the projet what was in the panel. I have now a .mer file but how i an import that to my rsview studio ?
thanks for help, artur
hi, this workaround dont work here to me.
But i found now on one laptop the project, but unly the folders from the hmi with a .sed file .
how i can import the sed file in my rsview studio se ?
I try to copy all folders to the current folder from rsview, but when i want to open the project, there is nothing that i can select.
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
92
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
50
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
73
363
123
