Connected Components Workbench Install HELP!
keithsimpson
Dec 2012
Bathurst
Hey everyone,
I'm a long time lurker first time poster. Searching threads here has helped me tremendously since I joined but I now have a problem but cant find a solution.
As the title says Im intalling CCW ver.4 on a WIn 7 64bit laptop but I'm struggling. It took around 3.5 hours for CCW part of the install to install but when it goes to upgrade controlflash it sits at 'please wait'. I let it sit there overnight but its still no good, so i canceled the install. I'm now trying to remove controlflash and do a fresh install but again its sitting at 'please wait'.
Anyone else had problems or anyone that can offer help will be greatly appreciated.
CCW takes a long time to install - this is normal.
you may have corrupted the install
by memory there is a specific way to uninstall it.
it is onthe website.
you need to follow this procedure.
I have not been online with V4 yet so I dont know if there are problems
Thanks for the replies guys but i finally got it sorted.
I had to use a registry cleaning and repair program to fix the controlflash problem. It found a whole heap of controlflash entries that had no destination. I had to run it 3 times in a row to fully clean it out but after that it installed fully and quickly, as well as slightly speeding up the load up and use of CCW.
If anyone has similar problems i suggest trying this method out.
I used Tuneup Utilities 2013 registry cleaner for this.
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
796
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
500
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,285
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,060
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,377
