connecting 3 device together via rs 232
Vazgen
Dec 2010
Tampere
hi everyone
i want to connect 3 instrument together via rs 232
one on is a mighty vacuum pump ,and one is Flow meter
and last one is delta P meter , i use of Citect Ver.6
for monitoring . pls tel me how can i read their data ? i know i can use of 4 - 20 mA analog out put but it is necessry to use of RS-232
hi everyone
If you are lucky, the instruments have the Modbus RTU option.
Check this first, and come back for more help if needed.
Kalle
Hi Patrick ,
thanks for guidance .as you know there are some wire in RS-232
TX - RX - Vcc ... pls tell me have i to use of device net for connecting ?or conect all tx together and all Rx together and ....?
i use of ADAM 4561(USB to RS-232/422/485 Convertet)i mean i have interface with rs-232 out put Now i don't know how can connect 3 moudule (as i said) to interface
I think that RS-232 only support point-to-point connection. You must convert RS-232 into RS-485 and than connect all "A" together, all "B" and all "signal ground"
Hi Vazgen,
I am not 100% sure what you mean... When using RS232, only two nodes can be connected and when doing so RX (on node1) needs to be connected to TX (on node2) and vice versa. And ground (normally pin5 on 9pin Dsub) should be connected to the other device ground.
If you have 3 Usb conectors free on the PC (Citec), theoretically you could connect your devices to 3 Usb-RS232 converters and get the data from the devices to Citec.
I would suspect that your serial devices either use raw ASCII output or some propritory serial protocol, either way you will need to handle that in Citec. If you cannot handle it in Citec, you might need to consider using a gateway as I proposed.
BR
Patrick Lansdorf
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
355
134
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
424
Hello, all! I’m having an issue with a new machine my company is designing. I’m trying to figure out if certain solutions are do-able, and from...
3,781
Hello everybody, Could you help me to connect profinet device over EL6632 profinet controller in the TwinCAT 3? I try to do that and I receive an...
1,884
