Connecting a plc to the pc via eztouch
powermonkey
Aug 2005
Austin
I was wondering if it is possible to communicate with the plc throught he eztouch screen? Also what software would be involved, and does directsoft handle this or would i have to go with screencreator? Thats it :) Thanks in advance.
PLC = DL05DR
eztouch = ez-s6m-r
Ad and Ez-Touch works well together.
http://.automationdirect.com
D0-05DR
8 DC IN / 6 RELAY OUT MICRO PLC W/AC P/S
$99.00
EZ-S6M-R
ECONOMY 256K NOT EXPANDABLE MONO TOUCH PANEL 6IN
$425.00
PC-PGM-BRICK
DIRECTSOFT PROGRAMMING S/W FOR 05/06/105 PLCS
$149.00
EZ-TOUCHEDIT
PROGRAMMING SOFTWARE EZ TOUCH
$140.00
D2-DSCBL
PC PGMING CABLE DL05/06 DL105 205 350 450
$30.00
EZTOUCH-PGMCBL
EZTOUCH PROGRAM CABLE
$20.00
EZ-2CBL TO ADC PLC RJ12 PORT EZ-TOUCH/TEXT CABLE $20.00
All most forgot the last cable
Based on the title of the thread, I think powermonkey wants to communicate between a PC and PLC through the EZ-Touch. As far as I know, you can't do this... :confused:
I assume you're using both COM ports on the PLC, and are looking for another way in? If the expansion slot is free, pop in an H0-ECOM (or better yet, an H0-ECOM100) and connect to your PC via ethernet... :cool:
-Eric
If he wants to look at the program then No.
But if he wants the PLC to make a spread sheet or graft in the touch screen and transfer that to the PC than yes.
Need a little more info.
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
181
Hello all. When I try to connect to a S7-1200 PLC (Tia Portal v17) which has a CP 1243-1 module that is connected to my clients network I get...
1,604
Has anybody worked with these IX sensors? I'm trying to use one with a 1769-L32E processor (running version 20) but the PLC won't recognize it...
1,996
Hi guys anyone had this before? Latest AX5103-xxxx-0011 xml files from Beckhoff's site added in the device repository using ABB's Automation...
3,155
Hello, i'm trying to connect a metering pump to a 1756-L61 ControlLogix5561 Controller. I have the metering pump and anybus module hooked up...
3,351
