Connecting Aveva Plant SCADA to Wonderware Historian
halberta
May 2023
Alberta
We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node.
Everywhere I look online I see I need to use the Citect SCADA Wonderware Historian Connector to enable storage from a Citect node to a Historian node, but now that Citect SCADA is under the Aveva umbrella I can't find any documentation on whether the Historian Connector is still needed, or if it will still work for this application.
Using the Citect SCADA Wonderware Historian Connector is significantly easier to configure the Historian than doing this manually or directly.
The downside of this approach is that whenever Plant SCADA is offline so is the Historian data.
It can be better to go direct from the IO device to the Historian eg. via an IOServer to OPC protocol converter/software gateway
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
57
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
64
102
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
119
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
253
