connecting HTL encoder to DL-06
JimR
Oct 2004
24
I am looking at using an encoder that has HTL output. I've never used HTL, only npn open collector type encoders. Can I use HTL directly with the DL-06? What exactly is HTL? Thanks.
I would discuss this with AD. HTL is High voltage transistor logic, normally its evaluated without the negated tracks so cant be evaluated differentially.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
95
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
103
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
235
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
150
