connecting PLC to inverter
sistyN
May 2013
Tehran
hi , i'm a rookie :) , I wan't to connect DVP-20EX (delta plc) to KEB F5 inverter with RS485, I know how send data to inverter but i don't know what must I send ? is there any tutorial or book , can u help me a bit ?
Is this inverter a Variable Frequence Motor Drive? Do you want to be able to Start and Stop the motor drive using the Delta DVP-20EX PLC? If not, then what do you want to do?
Yes, there are User Manuals for both the Delta PLC and the KEB F5 variable frequency motor drive.
ty , the most important is what data usually must send to control ineverter . is it the ascii code or hex code ? there is a function in plc to write data to inverter with RS485 , it has 3 argument :
MODWR S1 S2 N
S1 = Device Address of the slave (2 as we configure on steps 3, 4 and 5)
S2 = Data Address of the slave (H2102 to read output frequency)
N = Data to be read (3 words)
I read the KEB F5 manual and just find out some ascii code for controlling and I don't know what to do with them .
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
101
Ive been asked to connect a small PLC monitoring system for a fish farm to control 2 inverter for air blowers. The alarm systems have been set up...
5,504
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
67
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
85
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
257
