Connection problem with Micromaster440
denz52
Aug 2008
istanbul
Hi folks
I want to connect MM440 using pc-inverter connection kit (6SE6400-1PC00-0AA0) with drivemonitor or starter. But I couldnt. Normally I can connect the other MM440 in my office with same kit and drivemontor.
That MM440 connect to system with profibus. I removed BOP on the profibus modul after I took on pc-inverter connection kit (I arranged baudrate of course)..But I can not manage..
What is the main reason?
best regards...
I dont know what is the problem with your PC connection kit.
In case you dont get it sorted out, then I can suggest that you use some Profibus capable hardware to connect to the MM4 via the Profibus module.
I have succesfully done that before with a CP5511 and STARTER software (I think Drivemonitor do not support profibus).
Hello, I have an MVI56-MNET module, which is installed together with EN2TR, with a subnet of ~10, all instructions have been added to the project...
433
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
932
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,482
Hello there. I have bougth a SMC EX260 SEN-1 ethernet/ip slave and i want to control it from windows PC (with Modbus TCP may be?). Is it possible...
1,001
Having some issues initiating a connection to a S7-1500 PLC over Modbus. I have an OB created with a MB_SERVER block and a configured port (Port...
1,598
