contactor selection for capacitors
AC1 is for resistive loads
Heating is a resistive load
AC3 is for reactive loads
Motors and Capacitors are reactive loads
also modern high efficiecy lighting system tend to be reactive.
If you look at siemens and moeller for example, they have special contactors specifically for switching capacitors.
Thanks for ur reply, but in capacitor duty contactors, whn v r using it with the harmonic filters the resistors get burnt in many cases. so now we are trying to go for normal duty contactors because while using reactors the inrush current is taken care of by it
I need a little sanity check and hopefully advice from some experienced users. I have a mechanism that we're driving with a JVL MAC3000...
1,144
Customer want to use contactor for their 5HP motor blower application. im leaning to VFD. anyone use contractor for blower application...
331
Hello. We use AB PowerFlex 7000 drives in a pump station. The operator just called to report a fault on one drive: "STATUS: Faulted" "FAULT: DI...
665
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,114
I have a customer request that reads (slightly edited) Smart Motor Contactor This will monitor incoming power for irregularities in voltage...
2,408
