Control Logix to RIO with A 1771-IFE
Mudman171
Jan 2007
Tuscaloosa, AL.
OK, Let See where to start .
I have a L55 I am usuing RIO to replace several PLC-2 Processors all is fine I am on the 3rd one now and I have a 1771-IFE analog card. I have setup my messaging to do the BTW and BTR I have all of my tags the correct length I even have each bit named for the actual bit in the cards . Anyway my problem is I see data on some of the channels I thought this is good but after looking deeper,the data seems to be false.I placed a 4-20 simulator on one of the unused channels and nothing.I removed an input the seemed to be giving me data and the data stayed it even fluctuates like an analog reading. I put the simulator on it and adjusted it full scale and no real change.I feel I might be missing something I just know where else to look. I am writing
the exact configuration printed from the old processor before it was removed.I am at a loss. I still have about 5 of these to do and the rest are heavily reliant on analog data. Anyone, Something to help a bit here. Thanks
[email protected]
Best guess, you have your rack/group/slot addressing set incorrectly in the BTW/BTR and you are actually seeing data from one of the other modules, not the one you THINK you're dealing with.
Thanks for the fast response. I looked at last night and did the right clk thing on the message instruction and comm adn browse to the actual module in the RIO group . I am going to keep playing with it .
Keep The Thinking Caps On . I am despreate now but the time is coming
I got it , My problem was that my 20 bit read array and my 37 bit write array were DINTs instead of INTs Problem Solved.
One for the archives. Thanks for the help.
Hi all, I have an application where there is a Control Logix PLC connecting to a B&R remote I/O station over Modbus TCP via a prosoft MNETC...
1,917
All, This is my first time test and attempting to establish a DHRIO connection in my career, I am attempting to upgrade the main processor in the...
1,406
We are looking at replacing a PLC5/40E system that has 3 remote I/O racks, in separate MCC's, with a Control Logix setup. All chassis, currently...
7,505
Is this possible? I was told that there would need to be a PLC in the Remote Rack??? Why would you want a remote I/O rack with it's own PLC???
2,484
we are converting PLC-5 controls with control logix system. The idea is to replace only PLC 5 processor and retain all existing PLC I/Os. Most of...
5,340
