industrial 951
Hello,
I am having writers block on trying to determine what is the best way to limit the speed of a vertical turbine water pump based off rate of change, basically i dont want the pump to make extreme speed changes. does anyone have any clean ideas on how to control this? it would be nice if compactlogix had an instruction for this. one option i considered was to set the acceleration time on the vfd way up, but then decided against it. here is the layout
> i have a wet well with a level transmitter
> the speed of the pump is proportional to the wet well level from 6 to 12 ft depth (at 6 feet the pump is at minimum speed, at 12 feet pump is at maximum speed)
> i am currently using a pid instruction to control the pump speed (gain set to 1 , I and D set to 0)
> there is a mag meter on the discharge of this pump
