Hi
I have a twido TWDLCDE40DRF with ethernet plc , Ive got it connected via ethernet usinfg the ip address 192.168.1.2 .
I am making a remote guided veicle using a PLC and to display video information i have created an application in C# which has a flash ax control and uses camra.get to display the live video , It also captures the ^ V < > keys on the keybord .
id like to use these to control my drive motor which is connected to outputs 0.2 and 0.3 for forward and reverse motion . But im not sure of the code i should use to swich these outputs on and off .
Does anyone know what i should use to turn on output Q0.2 over ethernet with a .net or other programing language ?
(Twidosoft cannot be used because the keystroke functions must be used to turn on the output using a dedicated control application)
thanks
thanks
