Controller Data Exchange
ABnorm123
Sep 2022
New Zealand
Has anyone tried here to work with Mitsubishi FX3U as controller 1(connected thru serial) for Mitsubishi HMI E1071 then AB Compactlogix as controller 2(connected thru ethernet).
I'm talking about the Controller data exchange between 2 controllers(Dual Drivers) feature on E-designer.
I have done this from an FX2N, FX3U & SLC505 works well.
Been some time but see pic. Just remember, the E series is now not supported as it is end of life. Never done it to CLX but it should work.
Hi there, Can anyone suggest the solution to communicate between AB Compactlogix L36ERM controller(Which is having remote flex IOs over ethernet)...
3,701
I know there are not a lot of Beckhoff TwinCAT users on here, but I wanted to share this with anyone that may have a need for it...
5,384
172
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
320
I have been trying to setup a connection between a 1769-L33ER and a WAGO 750-881. The WAGO PLC is part of vendor equipment. I set up a Generic...
1,166
