Controlling 160SSC drive with Analog Card
Increment/Decrement numeric entry objects were added to PanelView firmware in version 4.0, so a project that is configured for firmware 3.0 (which yours is) won't have that option available. Look on the Terminal Configuration window for that [Firmware Revisions] button.
It's pretty easy to upgrade PanelView firmware, but that might be a step you don't want to take right now while you're trying to modify only a little.
Back to the pushbutton Add/Subtract logic !
(and attached is an example of increment/decrement and Move Up/Move Down buttons)
Yup.....
I got to work this morning since it was killing me to know around 3am and the PV I have on the bench is a 3.00 and the one that exists in the machine is a 4.20, so that is where my dilema lies, I am digging on my PB32 CD now trying to find the firmware flash utility. Right now if the one on the machine went out I could not just drop the one from the bench in place and it is the only PV900c I have, so going ahead and doing the firmware in a non-emergency situation is the way I am going to go, but went ahead and got everything drawn and dumped it to the screen and loaded my analog card and updated the rack and now it is a matter of the drive and a few wires.....and some brushing up on the mov command and getting my info where I want it. Back up a couple of post I believe.....
Thanks for the help guys, will keep up with how it progresses
Steve
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
143
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
591
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
219
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,208
Hi All, I am facing one issue with the SEW MDX61B drive. Issue- I want to run a conveyor with this drive in two directions but it runs in...
362
