ControlLogix Clock
dave b
Sep 2003
Does anyone know how a ControlLogix clock could be remotely set, from say a SCADA system ?
Only GSV is available for the .DateTime attributes YY/MM/DD hh:mm:ss, as they are decoded internally from the .CurrentValue
It may involve setting the WALLTIMECLOCK.CurrentValue DINT[2] array with suitable numbers, but does anyone understand how these are coded ?
I read it is an offset from 01/01/1981 0000 hrs, but can't seem to determine how the numbers work.
Please feel free to go into detail !! :p
The ControlLogix manual appears to be wrong.
I think that the WALLTIMECLOCK.CurrentValue DINT[2] is a 64 bit integer containing the number of microseconds since 00:00 hours 1 Jan 1972.
Your SCADA could calculate the number of microseconds since then for the time to be set, comm it down to the PLC along with a flag telling the PLC to execute an SSV command to set the WALLCLOCK.CurrentValue DINT[2]
:D
Hi Dave.
Did you get the Control Logix to sucessfully accept the time update from the SCADA system? I ask because I'm running into the same problem with a current programming project. Any advice you can pass along is *greatly * appreciated! ;)
From the SilverPlatter Department
Setting the clock...
copy the two rungs...
XIO(CLOCK_system_set)GSV(WALLCLOCKTIME,,DateTime,CLOCKreadvalues[0]);
XIC(CLOCK_system_set)SSV(WALLCLOCKTIME,,DateTime,CLOCKsetvalues[0]);
and your controller tags contain....
CLOCK_system_set BOOL
CLOCKreadvalues DINT[7]
CLOCKsetvalues DINT[7]
fill the CLOCKsetvalues array with the date and time then toggle the set bit.
Have at it.
Bitmore
Hi Dave.
Hi'ya Bitmore!
First off, Thanks! :) Silver platters are the best!
Another question: In the SSV does the CLOCKsetvalues[0] cause the whole array of CLOCKsetvalues to be copied to the processor, or only the value in the array space [0]? In other words, will I need a SSV for CLOCKsetvalues[1], CLOCKsetvalues[2], etc?
Again, much thanks!
Around The Block
More from the SilverPlatter Department
YES the whole array is written to because of the command
CLOCKreadvalues DINT[7] Decimal Get system clock values
CLOCKreadvalues[0] DINT Decimal Year
CLOCKreadvalues[1] DINT Decimal Month
CLOCKreadvalues[2] DINT Decimal Day
CLOCKreadvalues[3] DINT Decimal Hour
CLOCKreadvalues[4] DINT Decimal Minute
CLOCKreadvalues[5] DINT Decimal Seconds
CLOCKreadvalues[6] DINT Decimal Microseconds
CLOCKsetvalues DINT[7] Decimal Set system clock values
CLOCKsetvalues[0] DINT Decimal Year
CLOCKsetvalues[1] DINT Decimal Month
CLOCKsetvalues[2] DINT Decimal Day
CLOCKsetvalues[3] DINT Decimal Hour
CLOCKsetvalues[4] DINT Decimal Minute
CLOCKsetvalues[5] DINT Decimal Second
CLOCKsetvalues[6] DINT Decimal Microseconds
This is how the arrays are set up
Bitmore
Thanks - I'll give it a try!
Hi'ya Bitmore!
Thanks again for the info. I'll try it out when I get back to the processor.
Later,
Around the Block
I have problem to set wallclock for controllogix by using SSV.
2,816
I created a Date_Time tag and polling the year,month,day, hour, minute etc. but they are all wrong. The year for instance is showing 1998. Is...
1,593
I read previous posts about this but have a question:Originally Posted by roadwhore In Rsview Open Global Connections Tab under System Enter PLC...
4,903
70
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
97
