ControlLogix ethernet comms to PLC5 rack
There will have to be some downtime but, as with the nature of most projects, it is to be planned, scheduled, and fixed in timeframe so as much as possible will have to be done before shutting down. That is one reason I need to get an understanding of how the I/O will map over Ethernet, so the program can be added/changed as much as possible up front. I understand the old, one scan vs. new, continuous scan concept but, if I understand, this will be predicated on converting completely over to Logix hardware. Using the old wiring arms will be convenient but not that big a deal in the big picture. It is a full rack but all 16-point so not too bad to wire to new cards if necessary. However, if everything has to be replaced as explained, it will not be much more for the wiring adapters!
Hey everyone, Running into a snag while commissioning some PF753 drives onsite. We have a ControlLogix L71 processor with an EN2TR card in the...
1,991
Hello I am trying to set up communications with a controllogix PLC and an EZMarquee display. So far I have found a pdf (see attached) that is...
3,770
Hi, I'm am trying to get data across from a controllogix CPU to the Micrologix 1100. Has anyone managed to do this? I am having some trouble...
5,809
Hi All, I was wondering if someone here might have had to do this. I have to read a portion of data (200 words'ish) from the memory of a...
4,570
Hi All, Looking to get some direction on how to get data from a piece of equipment that has RS-232 communication (1-way) to a 1756-L73...
357
