ControlLogix String array values
Christoph
Sep 2003
Indiana
345
All
Working on a new program and I am using several strings that are arrayed. I am now trying to enter my initial data into them in the data area. It won't enter in. I have read the help on this but none of the suggestions seem to work. Any Ideas?? current data looks like '$00' can't delete, or over write.
Thanks.
The value should default to ' '. When you click in the box to change it, ellipsis (...) button should appear. You have to click on that and enter your text in the dialog box that appears. Strings aren't controllogix's forte.
Never mind. when yo click on the area to enter the value, a a dropdown comes up. You must enter your data in the dropdown.
Refer to attached picture.
1. Make sure you have the 'Monitor Tags' tab selected
2. You are probably seeing the individual character ('$00')
3. Click on the string array - just above the LEN if the string is expanded.
4. Click on the ellipsis (3 dot control) which appears then enter the string in the 'String Browser' window which appears.
Hello, So i managed to read the string coming from control logix and put a string display in PanelView 800. Now I am struggling to do the other...
155
I want to create a time stamp within my PLC when an event occurs and then read and display it as a string tag in my HMIs. I figured that someone...
1,671
Hello, I am trying to import machine data from a Controllogix PLC (L71) into an excel spreadsheet for my operations people to view from their...
2,373
PLC Gurus, I need a little bit help here.. A little background, we're working on a project using PlantPAx from Rockwell.. We use some of their...
3,387
I'm working with a system that has an OPC gateway server that is being decommissioned and on this server resides a Matrikon OPC Genie that serves...
4,515
