Convert a Float to String RsLogix500
Big John T
Nov 2006
Poplar Bluff
199
I have a number that is too big to hold in an integer file and must be in a float. Now I have to convert that number to a string to sent to a remote device... The number is a calculated number like:
240 x 1608 = 385920
The first number is a variable from the PV. The second is a constant multiplier. The third number needs to be in a string...
Any ideas?
John
Hi, I need to convert float to string in RS Logix 5000. I am using Comactlogix L32 E Processor. Pls advise how to convert values between 1.00...
3,824
Hi all, Going to use a ML1400 to talk to a Krohne gas meter via Modbus. Krohne's totals come as doubles (64-bit floats). I was wondering if...
4,732
I have a Float that is F45:10 and I need to convert it to an integer to display on an HMI that is in VB.net and we can't change. I look on the AB...
9,486
Hi, I read a modbus map in array of 350 elements. The destination is integer. Now I want to copy this array into floating point array while...
2,043
Jees... Continuing from this thread... http://www.plctalk.net/qanda/showthread.php?t=85341 I now have the correct pressure in Torr and mBar...
24
7,515
