Converting Rockwell to Siemens
Old No. 7
Jun 2010
Ohio
173
Working on a project where the customer requires Siemens PLC's (S7-1500) and HMI's (Comfort Panels). The project is similar to ones we've done before with Rockwell/AB PLC's and HMI's. We have both Compactlogix platform and SLC/Micrologix platform). Both used Panelview Plus HMIs.
There is about 5 different pieces of equipment each with their own PLC and HMI that are all different.
We tried the "auto conversion" that Siemens did for us on a different project (one Compactlogix PLC only) and it kinda/sorta worked, but left tons of errors to clean up and in that case it may have been faster to just start over.
On this project, there just isn't enough time to develop 5 programs (several hundred rungs, recipes, PID control, etc) and 5 HMI's (probably 50-75 screens each) from scratch.
Any recommendations? Our Compactlogix program uses lots of UDT arrays that I'm worried wouldnt' convert well or at all. Would converting a SLC work better/worse?
Any idea how well their conversions of HMI's works?
I am yet to see a conversion that looks well out of the box. I found the Siemens result from PLC5 better than Rockwell's, but I'm not an expert in conversions and may have missed a setting.
Unfortunately, I think that unless it is structured text, conversions will always be iffy.
Are the 5 systems similar in any way that you can move code from one to other? Siemens allowing functions and function blocks I would say that reusing code is one way to speed up the process.
Right now I am converting the other way (Siemens S5 to Controllogix) for a client. If you need help, let me know. I am not aware of any automatic HMI conversion utilities from Rockwell to Siemens or vice-versa. You would need the PLC done first so that the PLC addresses are defined for the HMI application.
You will only have to develop one from scratch. The remaining 4 is conventional copy paste development. On the bright side the 1500 is much more close now to ab programming.
Hi, I've been given the task of converting a B&R plc into a compactlogix, I have the source code *.PRG. Is there a quick/best practice way of...
1,645
I am looking to converting the Gem80 PLC logic in to Rockwell PLC. I need GEM80 Instruction Manuals, and documents that help you to understand the...
2,408
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
210
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
125
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
324
