Converting STL to LAD in S7-300
Ian S
Apr 2004
Sheffield
50
Is it possible to convert an STL block to display in LAD by default?
I would like to generate a source file and compile it into a ladder block, but I can only get it to be STL. I can't edit the "Created in Language" field in step 7 manager.
(I want to use a source file because I can auto-generate code from an Access database.)
Sure, I can open the file and use CTRL+1 to see the ladder, but I would like ladder to be the default. My customer's specification calls for the program to be written in ladder, so that's what I want to give them.
Regards,
Ian
Well, if you save the block when it's displayed in LAD, you'll see it in LAD when you're opening the block again. In the Step 7 Manager you'll see that the default language will be changed to ladder. I've not yet found any other way to do it.
Kind regards,
Hi i want to Convert this Block in Ladder Language.thanks AN M0.0 JC ntw2 CALL "BLKMOV" SRCBLK :=P#DB2.DBX0.0 BYTE...
1,668
Hello all, I have a Step5 program written in STL, and wish to convert it into the LAD representation. I've been told that this is possible if...
18
11,308
Hello, I opened sample project mix in step7. Problem is that program is mostly written in STL and parts cannot be converted to LAD. For example I...
4,832
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
226
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
361
