Conveyor increment question
amp
Feb 2003
Louisville, Ky.
I'm a 4th year apprentice and new to programming. I have the LogixPro simulator from the Learning Pit and have been working on a bottling machine. How can I increment a conveyor that has only 1 Prox? There is a Bottle present prox at the very beginning of the line and I have to use it to start and stop the conveyor. I know I'll have to use a one shot but I can't figure out to write it into the logic. I've got my Bit Shift commands doing the other operations needed, but have to get the start/stop now
Pretend that the machine has absolutely no automatic capabilities at all. You are the operator. You control everything - manually.
How do YOU get the desired effect? Put aside all assumptions! Put aside your personal memory... use a pencil and paper to log your memory. If you make judgements based on memory, those judgements can only be based on currently logged memories.
Once you figure out what it is that you need to know, play "Be the Computer" and figure out how you can use that information.
Give it a shot... talk yourself through it...
One of the signs of a truely experienced programmer is that you sit (or pace), staring right through things, flinging your hands around, pointing this-a-way and that-a-way, and most importantly... you talk to yourself! You are talking yourself through the "Be the Manual Operator" and "Be the Computer" processes.
While you play "Be the Manual Operator", the most important things to consider are, what exactly, am I doing, and why? WHY do I think this is the thing to do??? WHY-THIS? and WHY-NOW? Don't assume ANYTHING!
While you play "Be the Computer" the most important thing to consider is that all you can respond to are idiot lights that say something is either ON or OFF! You also have access to memory... but you need to consider, WHEN, HOW and WHY does any information even get into memory?
NO ASSUMPTIONS!!!
So... what-a-ya got?
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
215
Does anyone have sample logic with conveyors that start and stop according to product on the line?
114
Good Afternoon, I’m limited with a skilled maintenance staff to design and build Load Cell , Rollers , etc. for conveyor sections . Do...
675
Hello everyone, I need to create a belt conveyor with an AFM60 encoder on board that detects the position of the glass (too small to be detected...
731
"Hello, I am a beginner learning about PLC. Could you please give me some advice? I want to write PLC instructions as follows: When the sensor...
18
3,460
