Copying UDT instance values to another UDT instance.
Elcan
Apr 2008
NC
935
Hi All,
In RSLogix 5000 (or Studio 5000), is there a way to easily copy all the tag values from an UDT instance to another UDT instance (same UDT structure)?
Something equivalent to a MOV.
Thank you!
Hello all! Is it possible to COP a SINT array to a UDT structured the same as a SINT array, except all BOOL bits? I have a module that has an...
3,206
I created a UDT with recipe parameters and have created several Recipe tags using that UDT as a data type, as well as an "Active_Recipe" tag. if...
1,772
I have an application where I am allowing the user to edit 4 different XY value tables using 2 columns of numeric indicators on the Panelview. I...
3,772
I'm trying to reverse engineer a client's program. They are sending Logic Command and Speed Reference over DeviceNet to a PowerFlex 40P VFD. The...
3,276
I'm not super familiar with the Micrologix line of processors, but I am pretty familiar with RSLogix 500. I'm trying to simply copy a string to...
330
