counting pulse flowmeter
nasermehraban
May 2016
iran
HELLO
I have' a flow meter that continuously passes the milk and milk passage of which is shown on the display. So far, I have no problem, but I want to calculate the amount of flow passing through a period in the past and show on display
Is it possible the flow versus time graph on the display event? And then using the above graph in a specified time interval to calculate the amount of milk has been passed?
my pls is s7 siemens
best regards
Hello,
See if the flow meter has an inbuilt totaliser, if not create one. Use a counter or simple x = x+1 every time you receive a pulse from the flow meter.
Points to consider...
  • Figure out when it is product, so you only count product
  • Figure out when you want to reset your totaliser
As for these questions you will need to provide more detail,
Flow meter type/brand, also what display?
Ash
is the time of day always going to be the same?
You may need to write code to log a count and datestamp and then reset the count every day so each day you will get a datestamp and a count. This could be stored into a DB with say 100 days of data and you could increment the pointer each day or simply push the data down a row each day and fill from the top
Hi, any advice would be useful. We have an EL1512 that is counting pulses from a flow meter. We need to ascertain the frequency of the pulses as...
5,770
Hi everyone first of all. This is first question in the forum. I am using HSC application. I'm reading A and B pulse count. 1 round of the motor...
4,415
Hi There, I want to use a Zelio to monitor pulses coming from a device. If the pulses are higher than 0.5Hz, then the output is on but if it drops...
1,903
Hello All, I am using a Micrologix 1100 with a HSC counter. The HSC counter is working the way it should be. I am trying to detect the Duty Cycle...
2,359
Hi guys, I'm currently working with a siemens PLC 314C-2DP and am using the fast counter input(channel 2) with an incremental encoder...
5,172
