CP1L RECV function
Bobobodopalus
Feb 2020
Surrey
89
Hi all
I'm currently trying to do some communication between 2 cp1l-EM40dt1-d plcs over ethernet/fins,
i have made a routing table and i think downloaded to both PLC's correctly.
port 250 set to network 1
IP addresses are 192.168.250.13 and 192.168.250.14
however i did do this remotely through a VPN so maybe that has caused a problem?
i think the issue is with my RECV function though, it looks as follows:
RECV
D2998
D2998
D2010
MOV
#0001 reading 1 word
D2010
MOV network 1
#01
D2011
MOV node 13 inbuilt ethernet
#13FA
D2012
MOV 2 retries
#0002
D2013
MOV 1 second response?
#0010
D2014
someone at omron pointed me in the way of using the CPU011_recievedata10 function block which acts the same as the RECV function but is much easier to use.
got it working with that straight away
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,160
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,400
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,244
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,708
Hello everybody, I'm using a Cp1l-EM40 PLC for my projects and this morning I changed the PLC IP from 192.168.250.2 to 169.254.67.1, because I...
3,276
