CP341 Change RS232 transfer speed
hardw Config
Hello Gromit;
As Combo says, go to the HWConfig editor, double-click on the CP 341 icon to open the parameter page of the CP, change your communication settings there and download the hardware configuration to the CPU. That should do it.
Hope this helps,
Daniel Chartier
Hi i have a cp341 1CH01 Rs485 and et200m ,i wanna use that to interface with a non simense slave device ion7330 are any deference between 1CH02...
1,796
Hi guy 's, can i use cp341 modbus rtu to interface with a non_siemnes slave device , such as schneider ion7330 ?
1,954
Hi, I am using the CP341 for modbus RTU in an ET200 rack. Usually we are using the CP341 for this application in the same central rack as the...
1,060
Hi all, Does anyone have any experience trying to simulate a Modbus master using a PC, The PLC is a cpu 300 with a CP341 RS485. I am...
2,673
Hi, I had RS485 ASCII string going into a CP340 @ 9600baud rate. This was working fine. I had to change my baud rate to 19200 so I got ripped...
2,526
