CP343-1 lean TCP connection
engineerjaber
Sep 2013
Ramallah
23
Dears,
I'm to modify an PLC program to communicate with an RTU through TCP/IP modbus connection.
The existing PLC, alreay has two racks, the first one which contaians the CPU has three free spaces.
the last module in the first rack is cp343-1, in which an S7-connection is established to a remote partner. and configured as active partner.
I'v have alread added the new CP343-1 lean to the hardware configuration. added it to a new network with anew subnet mask, but without adding a new connection, and re-downloaded the modified project to plc. with no problems appeared and the S7-connection still gives me the green " SET UP " message.
But, when i added a new connection to the new network (TCP Connection) to configure the new CP343-1 lean as a sever (withoun any modification to the logic and blocks), and re-downloaded the new modfied project to the PLC again, the s7-connection lost and gave me a red message "not set up".
How can i solve that problem ??
please, it's urgent !!
Hi! Right now wo are trying to establish communication between two Siemens CP 343-1 Lean Ethernet modules with CPU314 IFM. The problem is that...
24,567
I can not see the CPU s7-300 i only see the cp343 as photo the interface is through tcp/ip how can I upload the station via the cp343 module ???
1,012
Hi all, I have a CPU315-2 PN/DP with a CP card, which is CP343-1 Lean. I have a PI server and am trying to connect to the Lean card. I can ping...
3,748
Hi everyone, I have recently installed Siemens CP343-1 lean Ethernet modules (firm V3) on existing production line machine PLCs. Installation of...
7,718
Hello, I am facing problem in installing the cp343 lean with cpu 315-2 pn/dp. the cpu is conected with 4 distributer controllers as for...
1,552
