Cp343-s7300
johnmck66
Aug 2007
Manchester
96
I am trying to use a S7300 and a CP343, for a small test project, but never used AG_SEND, AG_RECV blocks before, are there any programming examples out there where I may be able to get a feel for the use of them.
In your Simatic Manager, you can open the sample project PROJECT_ETHERNET_en.
It is quite basic, it constantly sends a datablock from one S7-400 to the other. You may want to send less frequently.
Also, beware that the AG_SEND and AG_RECV blocks for S7-300 and S7-400 are different. You must copy the blocks from the SIMATIC_NET_CP library CP 300, not from the above mentioned sample project.
Hi all, I am tasked with quoting a solution in which our two S7300 PLC's with added 343-1 LEAN CP is supposed to communicate with two WAGO IPC...
2,965
I have problem with connecting citect with S7300 CP343-1 through PSDIRECT , i follow procedures of manual but i one of installation steps need to...
1,751
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
337
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,347
I have an S7-300 and an HMI. The HMI is the only device that talks over Profinet through the CP343-1 module. It's run fine for a couple of years...
517
