CP5512 Won't Appear On XP Laptop
Aabeck
Feb 2013
Detroit
1,860
I have my XP laptop that has Step 7 installed, it is the laptop I use that has a serial port & PC slot for my 5512 card.
However, recently the 5512 does not show up in the PC/PC Interface list. According to the help it is Plug-N-Play, and should automatically appear when inserted.
It appears in Device Manager & shows as working properly. I have tried updating the driver, uninstalling it from Device Manager, repairing then uninstalling Step 7, all with no result.
I have searched the forum and found something for a newer Windows about renaming a ProgramData database folder to .OLD then starting Simatic Manager in admin mode - but XP does not have the ProgramData folder that database folder was shown in, and I haven't found where it would be in XP yet.
Does anyone know where this folder would be in XP? Or is there another procedure I should try here?
On the side - I did put my USB adapter in & it immediately showed in PG/PC interface and I am using it - but I would rather keep that with my Windows 7 laptop that has Step7 & TIA on it.
nhatsen,
I have searched AppData and Application Data folders for all users.
The other post says: Go to C:\ProgramData\Siemens\Automation\Simatic OAM\data\LogDevices
Rename the data folder to data_old
In the All Users/Application Data/Siemens/ there is a folder named Automation - that is the only place any folder named that appears, it does not have a folder Simatic OAM - I searched the entire C: drive and no folder shows, also a search for LogDevices has no results anywhere
The only place a data folder shows is Step 7/S7DATA - but that has quite a few folders and files in it so I don't want to do anything to it until I am sure what I can do to it.
sigmadelta,
I went through all the steps they listed, had to search the registry as no 5512 entries were where they showed, found them in another section. Deleted them all after I backed-up the registry.
Tried opening Simantic manager as an administrator, even uninstalled the driver AND Step 7, rebooted then reinstalled, ran as administrator but still no 5512.
Right now I am uninstalling ALL siemens software, then clear the registry and Device Manager, then reinstall Step 7 first & see if that works.
Just to keep everyone updated:
After putting the 5512 in another laptop with a PC card to make sure it was good (it works) I tried System Restore; uninstalling, deleting the Siemens folder, deleting all Siemens keys in regedit (after a backup), and reinstalling Step 7 - still nothing.
I had to end up reinstalling Windows XP (a fresh installation) then when I reinstalled Step 7 the 5512 card and all it's options appeared fine and test ok.
We recently got a new laptop for our use and it no longer has a serial or PCMCIA slot (hooray, technological progress). We have a spiffy CP5512...
3,432
Hi, A year ago we decided to go to VMware to solve issues with different software instalments. This works great, except that the (very expensive)...
4,258
Dear all, Can anyone suggest me the way of communication between Siemens S7-313 plc to Microsoft excel can anyone let me know the price of...
2,005
Hi All, I received a new dell laptop model E5520 and I'm having problems getting the CP5512 pcmcia card to work properly. When comparing a program...
2,330
Hi, I need to buy CP 5512, but at ebay I found some clone for 400$, look here...
22
7,775
