Cp5611 To Segment Couple Without Cpu
teh
Supporting Member
Nov 2002
140
HI FOLKS,
Is that possible that the CP5611 Communicate with DP/PA link and Segment Couple without any Simatic CPU?
Regards
Yes, I think so.
You need Simatic Softnet PB S7.
With this you can setup a "PC station" that communicates with a Profibus DP network that in turn connects to a Profibus PA network via a DP/PA coupler.
Via the "PC station" you can then access the network via OPC for example.
I dont know so much about the PA stuff though. But I just tried to setup a network with Profibus DP --> DP/PA coupler --> Profibus PA, and it was quite easy.
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,490
Hi I need some help!! Siemens Simatic Net 2006 cp5611 has been discontinued, I have a PC with a dodgy hard drive so looking to do a new install...
1,691
Hi! I must communicate two CP5611(master-master) cards trought PROFIBUS ,but i have to use different driver than STEP7. I just found a citect...
1,475
Hi, I`m looking for purchase a CP5611 (6GK1561-1AA01). Siemens has stopped selling it, only if you have already they can sell it as spare...
1,732
The Siemens Simatic CP 5611 does not start on a VMware virtual machine, with Windows XP SP3, installed on a Field PG M3. It gives an error: "...
1,975
