CP5613 Siemens
jattuwit
Feb 2007
Thailand
Hello, Please help me.
I'm try to online S7-Manager via CP5613.
I'm setting to PG Operation and Change Online to CP5613_5614(Profibus) and setting parameter already.
But It not connect and have some errors or sometimes computer will Hang.
I'm use CP5613 connect CPU315-2DP dilectly via DP Port.
Jattuwit
Has your 315-2DP been configured yet? If you are going to connect with Profibus, the 315 needs to have been configured to communicate via Profibus. So first see if you can communicate with it via the MPI port on the 315-2DP. Make sure your PC communications is set for MPI not Profibus. Since you are having communications problems, I recommend doing this first even if the 315 has been configured to communicate via Profibus.
First of thank for your idea.
Yes, I'm create DP master in CPU315-2DP already.
and If i use PC adapter I can online PLC.
However, when i use CP5613 it cannot online.
An old Intouch application 7.1 was working with a CP5613 link with S7 CPU 315 2DP , de CP died . Now I have the new CP5613 A2 with de simatic net...
1,624
I have a Dell Optiplex260 with Windows 2000 on it. The PC asks as an operator interace to a Siemens CP342-5 using a CP5613 card in the PC to...
10,641
Some years ago I used CP5611 card to connect to an S7-200 PLC and program or monitor it. I have an old CP5613 and I wonder if I can do the same...
8,382
Dear All, I have ordered "SIMATIC NET Networking for Industry V6.2" software and "CP5613 A2" PCI Card. Can I connect CP5613 A2 to the MPI port of...
4,982
Hello, Received pop-up message on PC, saying I must restart CP (our PC has CP5613/CP5614 card) to continue work. Also such info, in same error...
1,585
