CPT in RSlogix5000
PLCgen
Oct 2014
Barcelona
I am used to the SCP function in the Rslogix500 but I'm not quite sure how to scale inputs using the CPT instruction and I need to use it because SCP is not included in 5000 and CPT is what i am instructed to use.I need to scale inputs from some transmitters (level,temperature and pressure).I have a 4-20mA, 0-10 psi hydrostatic level transmitter, RTD,dc probes etc.
Also,can someone explain the SCP instruction in detail just to clear up any misconceptions.
We tried the selection #15 - EM Brk Cntrl, and it worked exactly how I wanted. We even fine tuned it with on and off delay from parameter 86 & 87.
I just create a new AOI called SCP using function chart routine, drop a SCL on it and open all connections. Then use in in the ladder logic. Only hitch is you have to create a tag of the type SCP (matches the AOI) for each block you create.
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
160
In the CPT in rung 2, i'm having an issue where if there is any value less than 0.0115 in "verticalSpeed", "festoonPosition"'s value does not...
1,118
I have ran into something I have not seen before and wondering if any one had any ideas. The logic I'm currently troubleshooting is using a...
1,665
so I have to find the standard deviation for amperage readings at my plant. when I input the formula into the CPT instruction it is automatically...
1,859
Hello, I am having trouble with the CPT in RSLogix 500, with a ML1400. At first I had everything in one equation, it gave me the Source and...
2,031
