CPU m340 connectivity problem
firesoccer
May 2013
alexandria
Hello Dears
Im facing a problem in connecting to M340 CPU through mini USB , i tried many things to fix like reinstalling the usb driver again , trying another cable , changing the usb port in the laptop but nothing works , when i opened the usb hub from the device manager menu i found the
Well it looks like the USB driver is correctly detecting the processor. Show us the settings you are using in Unity Pro or Control Expert
Were you able to connect previously? There was some issues where if i connected once and disconnect and take out usb and put it back and try to connect again it stopped working. Usually I had to stop the usb service from running and the it would work again. Or restart windows.
Make sure that when you plug in the usb cable in pc and plc that in your taskbar at the bottom right of windows a small icon with usb written on it pops up.
Normally there is always a modbus driver icon there but when plugged in a usb icon should appear as well
you should have on Unity / Exostructure these com settings selected:
Media : USB, address: sys.
If you have USB icon, of which Chud writes, it should be posible to connect
the problem that i hear the sound of connectivity on windows , but no usb icon appears. it looks like it's a problem of driver but eventhough i reinstalled the driver but nothing changed
A few registers have now become NAN due to a divide by zero. I have taken care of that condition but the NAN has returned to some of the registers...
1,664
Hi all, I'm newbie about Schneider PLC M340 family, someone knows if is possible change the CPU IP address by means of some instruction to use...
7,917
Hello every one hope all are enjoying. I have an issue to connect omron NS10 HMI with CJ1M-CPU11 ETN plc I have made all required setting as...
24
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
56
I have a 90/30 CPU331. I am trying to upload the program out of the CPU and keep getting an error uploading the logic. Error 8262: Error...
123
