cpu time reading
tulip
Oct 2005
ist
236
Hi,folks..Where can I find example for cpu tıme reading for S7-300 plc (hour&minute)?Thanks...
Hello tulip;
SFC1 will read the Real-Time Clock of your processor:
The tag that you will use to write the CDT output to must be formated as a Date_and_Time variable.
Here is (from a preceding thread) the way the info is distributed inside the Date_and_Time variable:
http://www.plctalk.net/qanda/showpost.php?p=177998&postcount=2
Hope this helps,
Daniel Chartier
Hey guys, good day to you all Once again i find myself needing to ask for advice :embar: I,ve been trying all day to setup and read the time out...
9,677
Hello every one hope all are enjoying. I have an issue to connect omron NS10 HMI with CJ1M-CPU11 ETN plc I have made all required setting as...
24
I have a 90/30 CPU331. I am trying to upload the program out of the CPU and keep getting an error uploading the logic. Error 8262: Error...
123
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
327
