CQM1 Timers
kjwudsph
Nov 2008
Stoke on Trent
Hi does anyone know how change the timer settings on an old omrom CQM1 plc - I need to get 30s time periods but the timers only accept a maximum value of 255 milliseconds
Any help with this would be much appreciated
Thanks in advance
CQM1 has two types of timer instructions. TIM has 100 msec resolution and TIMH has 10 msec resolution.
How are you trying to set the values - from HMI screen? or using programming software like Syswin or CX-Programmer? or handheld programmer like CQM1-PRO01? If you are using software or programmer then which timer instruction are you using? (None of the two instructions can have set value of 255 msec, you can either have 300 msec or 250 msec)
SVN
Hi, I'm trying to convert some Omron code into SLC500 logic. This is from an old Sysmac CQM1 Omron plc. I can understand most of it, except for...
7,465
Hello, I know little English, I want to use 4 plc cqm1 as slave (modbus), and hmi delta as master. Unfortunately, I cannot establish rs485...
611
Hi! Has someone a pinout and/or wiring diagram for an old CQM1-CIF02 cable? Thanks!
1,926
Hi; I have a DUPONT brand machine having OMRON PLC CQM1-CPU21-E. I have CX Programmer installed in my Laptop having W1indow10. I want to go...
3,652
Dear All, Does anybody knows Omron CQM1 0ch Module details?? or manual i try to search but cant find manual or complete order code if this...
2,398
