Creating An EDS File for DeviceNet
recondaddy
Apr 2006
Atlanta, GA
77
Hello everybody,
I'm fairly new to DeviceNet, which means I can do pretty well as long as I have known devices with EDS files that I can access.
However, I have a device (pressure regulator) that I'm putting on my DeviceNet network. The manufacturer doesn't have an EDS file available, but tells me that I can get whatever I need from the cut sheet they provided me. I have included, at the bottom of this post, some of the technical data from the document.
I was hoping someone could show me how to derive the data I need from this document in order to build my own EDS file in RSNetworx for DeviceNet.
Thanks for any help you can provide.
Protocol: DeviceNet Ver. 2.0
Comm. Speed: 125k, 250k, 500k BPS
Slave Type: Group 2 Only
Device Type: 00h (Generic Device)
Connections Supported: Explicit Polled I/O
Input Signal: Indicates input signal by 12 bits (resolution 4096)
Output Signal: Indicates output signal by 12 bits (resolution 4096)
(Does this mean that for the I/O data in my configuration, I should check the Polled box and enter 2 bytes for input and 2 bytes for output?)
Technical Data:
ex. In case the pressure is set to 0.3Mpa for 0.5MPa F.S. specification:
(0.3MPa / 0.5MPa) x 4096 = 2458 (DEC)
Hexadecimal value for decimal 2458 is 99A.
RSNetworx can create a "Stub EDS" that allows it to at least recognize the device and put it into a scanlist. Right-click on the unknown device and run the EDS wizard.
Their description of 12 bits each for the Input and Output data isn't perfectly clear, but if you make a mistake in the EDS creation you can just modify it in the Scanlist. Start with 2 bytes in/ 2 bytes out and go from there.
What exact make and model of pressure regulator is this ?
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
704
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
82
Hi everyone, I'm a last year student at the university in Ghent, and for my thesis i need to write a TwinCAT program that writes data to a .daq...
149
When I go to create a new module in Studio 5000 I can't enter any information for the IP Address or change any other fields. Is there any fix to...
258
Hello I am kind of new to the Rockwell world, i've mainly worked with Siemens and Schneider untill now. I am to make a HMI application running...
1,072
