Crimson 3.0 Emulator with Compact Logix
DamianInRochester
Jan 2011
Rochester NY
1,292
Using Crimson build 484.000 with driver "Allen-Bradley Native Tags via L5K file". In Link options I have "send to emulator" checked, and the emulator is pointing to my Ethernet card. Connection is fine because RSLogix5000 is talking fine with the L35E on the same PC, and the FTalk runtime also works fine. I am running on a 64bit machine but inside an XP virtual machine. The RSLogix5000 and the FTalk is also in the VM.
The emulator does execute and boot up, but it does not appear to be accessing the PLC tags.
Under Network, I have the port mode set to manual config.
I have an additional free IP allocated to the port settings of Ethernet 1.
Not sure what else to try. Anyone else have any luck with the Emulation in a VM?
Hello Kind Folks, On my Red Lion Crimson, the "Send to Emulator" box is greyed out, and thus I'm unable to run the emulator. Has anyone run...
3,477
Hi Experts! I am trying to get a Redlion Crimson 3.0 HMI to talk to a Rockwell Emulator. I imagine I'll have to use OPC DA. Has anyone done this...
1,187
Using a Raw serial driver in Crimson 3.0 I'm trying to test some code. I've written some code to transmit so ascii characters with PortPrint() and...
1,098
Hi there, I'm very new to all this and I would like to ask for a bit of advice. If possible, can someone please point me in the right direction...
1,188
Hi, Has anybody found a way to make RedLion Crimson 3.0 Emulator "talk" to Rockwell Studio 5000 Emulate (within the same PC, running Windows 7...
1,964
