Crimson 3.0
tb844
Jun 2010
Carpentesville, IL
Trying to set up a reset button to accept alarms. I put the "AlarmAcceptAllAlarms()" function in the button data in the action block tab. It comes up with "this expression has side-effects".
I searched the manual for "side effects" in the manual and reference manual with no results.
What am I doing wrong?
I see that alarm message when a script may cause a circular reference. I think in your case, the first part of the text is a reserved keyword that, according to the manual, "This function is not implemented in the current build."...
I think silva has it right.
For my accept all alarms button, on the action page, for "On Released" I have chosen General and have "AlarmAcceptAll()" as the command.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
143
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
275
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
122
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
104
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
95
