Crimson 3 Bitmaps
leblar13
Jul 2010
louisiana
I would like to take a bitmap (symbol) and edit it. Is there a way to export them. Or can Redlion give me a copy......
I want to change the color of a 3 position selector switch. So when a pump is in auto, have the color change when the pump is running. I would overlay the different color.
Or
Any other Ideas....
Andre
At the very least you could take a screen shot of the bitmap, crop and edit it in MSPaint or similar, then re-import into Crimson.
leblar13,
If you are looking at the symbols in the resource pane and you double click on a symbol you will have the ability to choose one of many colors. You can then use a different color for each position.
Jeremy
Yes you are correct. You could make your own three state selector with the IMG primitive and selecting your own three images from the symbol factory.
Jeremy
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
157
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
311
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
136
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
125
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
99
